1 - 2 of 2 Posts
After about 30 seconds of idling, it shuts off. When it does, there is no power to anything. No lights, everything is dead just like the battery has been taken out of it. Leave it set for a couple of minutes, and it'll fire right back up. Any help with this would be greatly appreciated.
thanks, Ron
check the battery cables are good and tight. test the battery voltage, should be between 12.6-13vdc. then test the battery voltage with the machine running @3,000rpm, should read 13.5vdc-14.5vdc.
1 - 2 of 2 Posts
