i would check all the way down the wires looking for anything broke or cut. stators do go bad, but its not common to see them go. there are aftermarket companies who rewind stators, a simple google search should help there. find a good mechanic or shop you can trust and have them test the stator before you buy anything. i may be wrong here, its hard to tell.
if your coils are bad, and you have to buy #3, its a $476.98 part full retail. thats why it is super important to figure out what is bad. most electronic parts are non-returnable so dont start buying parts to just throw at it
3089959 PLATE-ASM
Subbed from 3089906
Part was advanced to minimum order quantity 1 $476.98
# Add Part# Description Quantity
1 3084997 Plug, Spark 1 Usage
2 3084978 O-Ring 1 Usage
3 3089906 Asm., Plate 1 Usage
4 3081657 Asm., Bolt and Washer 1 Usage
5 3089905 Flywheel w/Ring Gear 1 Usage
6 3084973 Seal, Oil
