Hello, I'm new here, this is my first polaris, this bike has been sitting around a lot, I just got it and it has a brand new battery(full charge), I have checked all grounds, fuse links, fuses, can't find any broken or damaged wires, the engine will turn over when I cross the silanoid, but it literally has no electrical power, no lights head lights or brake lights, my question is, are they an electrical component the would control all of these things?? It has fire going thru all fuse links and one wire is hot in the main harness plug in, also when I checked the fuses fire will come thru the center fuse when the key is turned on, so I'm thinking there must me an electrical component bad, any help would be greatly appreciatated!
Welcome to the board.
Hopefully you solved the issue by now! What was the problem?
