1 - 2 of 2 Posts
I aquired the bike in April and right off the bat I needed to fix the stator wires that had rubbed through, it runs, shows rpm,s and charges the battery so it's working fine, have a new plug in it, when I drive the bike from idle at 1100-3000 rpm it runs fine. From 3000 - 4000 rpm it sputteres and if you keep the throttle there it will kill the bike, if you release the throttle and get it below 3000 its fine. Or if you give it more throttle and get it above 4000 it also runs great. Has new gas with gas line a/f and a bit of sea foam. The flywheel has a cracked magnetic with a chunk missing on it not sure if this is the culprit but don't have the 400$ to find out so just looking for some help :hmmm:
thanks!
1 - 2 of 2 Posts
