My '06 Sportsman HO EFI is having fuel pump problems. I have spent several hours reading all the many fuel pump threads and studying a manual and wiring diagram but have not found my problem.
In normal operating conditions, the fuel pump will not come on. In the course of troubleshooting, 12v was run directly to the pump which will come on and pump fuel. The engine will crank and run like this.
At the fuel pump 3 prong plug, the red/green wire is seeing 9.3 volts at all times, does not go higher when the key is turned on.
The pump coming on with 12v applied directly says continuity is good from the plug to the pump and a consistent 9.3v at the plug says continuity is good from the PDM to the plug.
Next step was to remove the PDM and check for obvious problems, thinking 12v is not getting through a solid state circuit breaker. The PDM appears normal, plugs are good, no damaged wires found, no foreign materials were found inside and there were no burn smells or marks.
This machine has not been run since April so the battery was brought to full charge with a 2 amp charger and the fuel tank removed, drained and fresh gas used.
Any ideas what my next step should be? Should I buy a new PDM? Could this be ECU related? Any thing to check in the ECU? Studying the wiring diagram, I could not determine an ECU output that effects the fuel pump.
Any ideas of where to go next would be greatly appreciated
