New to board, have 2 '06 Sportsman 500 ho's. I ironically both them a week apart and over 100 miles difference in origin and both blue.
First one had to clean carb to get it to run with the choke off, guy cut a piece of plastic tube about 1/4' to keep the choke cracked so it would run. WOW.
Now that's been about 2 months ago. The first one I bought is my daughters and is having a funny problem. The tach, when you first crank it will work fine the when you rev up it bounces around then goes to zero and stays. The first day it did it it also made the battery symbol come on. Since that has stopped but the tach is still crazy. Doesn't seem to effect the performance of the machine but just wondering if this is a sign of something worse coming.
I've taken every electrical connect I can find and unplug and checked for corrosion or burning and found nothing. Pulled the drain plugs from the pull rope housing just in case there may have been water but nothing came out.
Can someone tell me where the tach actually feeds from?
My next test, on the next non raining day, is to pull the pod off mine and put on hers to see if I have a bad gauge.
Any ideas anyone?
And thanks in advance for any help.
Also, was $3100 a good price for an '06 with 550 miles showing?
Brian Conley
Palatka
My daughter loves thing and would hate for it to die at one of the local events like Hog Waller next week.
Any ideas anyone?
Brian Conley
Palatka
