07' Outlaw 500 IRS
How much freeplay is my center rear hub suppose to have if any? I am waiting on a new sprocket and noticed a loose rear hub. I have a manual for the quad but could not find anything referring to this issue. I would also like to know how I can find out if this quad has been serviced for the recall on it.
Discussion Starter · #2 ·
No help or thanks to this board.....
Is anyone out here? I have torn the hub apart after hearing a bearing loose.....the hub should have no freeplay and was easy to replace the bearings after the pulling apart of the hub. The hub also needed to be pressed back together. IT was an easy job. If anyone has any questions...or is even out there.....Ill be glad to help......
lol, gotah give some time for reply post my man. yes you are correct should be no visible play. as for the recall get the vin# and contact your local dealer to look it up.
Discussion Starter · #4 ·
I posted in February .......
And made the second reply todaY 6-26-2010....... How long should I wait...Thanks....
How did you split and put hub back together , Say you need a special tool in manaul which i can not find anywhere.
Discussion Starter · #6 · (Edited)
