hi fellow wheelers
I've got an '07 500 X2 with about 1400 miles on it & close to 168 hours. mainly use this for plowing in the winter and trail ridding in the summer. we ride pretty hard on the trail mix of mud/rock/dirt with some bush whacking/new trail or linking trails together. all I've done for the past 6 years is change the oil before every summer. What else should I be doing? Runs great except it vibrates more than usual, could be the body though. Please any info would be great. if you could let me what I can do myself and what i need to take it in for that would be great. I would ask my local Polaris dealer but they can be difficult and snobby when i don't know a detail or sepecific part. Let a brother know will ya!
Would be a good idea to service trans. Frt and rear diff fluids.air filter.fuel filter. Vibration ck for possible broke trans or motor mount.. ck wheel brgs for play.
Welcome to the forum! Grease the fittings, change the tranny fluid & the angle drive fluid. Also check your cvt belt for wear. If you don't have one get a service manual. It'll save you some aggravation.
Discussion Starter · #4 ·
Thanks guys. appreciate the advice. will start working on it.
The X2 doesn't have a rear diff. It has a tranny and it is all one piece. I would change the front difff fluid and the tranny fluid. For vibration you could have a tire out of round, U joints going bad, loose lug nut and other possible things. Check your air filter also.
Ronnie
