My Sportsman died two years ago and I finally got the stator replaced. I finished getting it back together and I went to start it the display would flash and it would not turn over (did not appear it through a full start sequence i.e. all the noises I remembered hearing EFI and such). I turned the key on and off multiple times and the display finally stopped flashing and it was able to start it. I ran for 30 sec or so and died. I tried to start it again and it started flashing again and would not start. I left the key on for a while and the display stopped flashing and i was able to start it up. I was able to ride it around for 10 min or so and it put it back in the shop for the night.
I went back today to change the oil, and it would not start again. All it got was a flashing display and it would not start. I took a video with my phone and I hope it will help someone tell me what to do next.
Thanks,
Mike
Video of problem
Welcome to the board!
Disconnect the stator and try it.
Sean
Hi Mike, I have a 2007 500 efi x2 and am chasing a very similar problem. My problem started with a similar flashing speedo. My bike started one time, ran fine and then I parked it for a week and would not start again. Now my speedo does not flash anymore and I only get an electrical clicking noise when I turn the key to the on position. My dealer told me is probably the main computer as they have had this issue on this year and model.
I am tearing my bike down to try to get this fixed and will keep posting as I learn more.
Good luck.
Thanks,
Rich
Follow up:
After researching the issue I described above, I ended up replacing the computer (part #4011657) and the battery. My '07 still had the original battery. Problem solved!
Good luck,
Rich
