I was warming up my atv yesterday,after about 10 minutes,I heard a (shotgun blast).My atv split the:suspect: engine oil tank in half!!I will replace the tank w/new one.Is there anything else I should look for?
Search around. There are other posts on this. Something about a vent getting plugged or clogged with ice or something like that. Causes pressure to build up and make the tank explode.
I used an aluminum pre-2002 sportsman oil tank.
It was some work to clean up and refinish but it fits and it's not going to explode because it's cold.
From orbit via Android.
08-400ho
Pulled er apart today(warm garage),and found water in the vent hose that comes up by the coolant overflow.I'll make sure and warm w/hairdryer next time in the cold!!:cowboy::fest06::
