i have a 2008 sportsman 500 ho efi...and it stalls and sputters sometimes i thought it was the fuel filter but i changed that and it still does it
the last ride i went on i shut it off and it didn't turn back on so i brought it down to the dealer and they said the pump only had 19 lbs of pressure and that i needed a new fuel pump so to get to the point they said i can only get the pump and the tank together for a little over 1000 so i was wondering if anyone knows a replacement or if there is another tank assembly that fits this year
mine is a 2007 polaris sportsman x2 800 efi twin the carter fuel pump fit perfect and strainer is a direct match the carter number is p72118 and the fuel pressure regulator is a standard brand part number pr210 the regulator has a tip on the side I scored the tip flush with a pair if side cutters then cleanly snapped the tip off I got mine from a federated parts store they had the pump in stock
