1 - 2 of 2 Posts
Could someone give me specific instructions on how to locate the fan circuit breaker? The fan has not been running so I disconnected the thermistor wire and the fan still didn't some on. I would like to check the fan circuit breaker but I can't find it. I would also like to konw how to test the fan relay to see if it's functional.
If you disconnact the thermo wire the fan should come on. The circuit breaker should be located under the front of the headlight pod, just take the cover off in front and below it. It will be wrapper up in rubber like a bike tube material. It's half the size of a 9 volt battery and has two wires going to it and has two bolt like connections on it. I couldn't find one to replace mine with so I just changed it to use a fuse and have had to change the fuse a few times. Let me know if your still having troubles finding it
1 - 2 of 2 Posts
