I have a 2009 Polaris Sportsman 550XP that has had a problem with the shifter sticking since the day I bought it new. With engine idling, the shifter will stick most of the time when shifting up or down. It'll stick going from P to H, H to L, R to P, etc, etc. And when I mean stick, it will reach a point where it binds up and I have to shift the other direction then back again, often multiple times to get it to go. It is so bad, that after only ~500 miles total riding, the aluminum Bellcrank15T (last part of shift linkage) completely stripped. Also, even when I can get it to shift, it is very hard to get it into Neutral. When the engine is OFF, I can shift up and down with no sticking at all.
The original Polaris dealer looked at it before first service (~10 hours) and told me to give it more time and that it'll work itself out eventually. Then they went out of business right before warranty expired!
Another Polaris dealer has looked at it twice. They have done the following:
- Verified proper idle speed (1650+/-)
- Checked both Clutches
- Shimmed clutch
- Replaced ASM Clutch One-Way (#1322809)
- Spoke to Polaris Rep - no useful info on this problem
The result -- no improvement, or if anything, maybe even a little worse. That dealer is completely stumped at this point.
- UPDATE 9/1/2011 -- I replaced belt with Dayco XTX2244, only MINIMAL improvement
I just want the dang thing fixed -- any ideas????
- Shimmed clutch
