my sportsman is squatting and the rear shockswill not return to their normal postion by themselves. Also the rear tires look like this/\ what causes this.
Weak springs. Buy some heavy duty versions.
Mine was squatting funny on all four corners.
Ordered some HD EPI springs and put them on. Sits fine now.
Was a relatively easy job. I used some spring compressors to help on the rear springs.
If you eventually decide to do the fronts, you do not need compressors for those, and be careful to not let the the fronts drop so that you mess up the CV boots or joints. DAMHIKT
yeah if u have already cranked up he preloads and that hasnt helped look into some epi's.
Soft springs can do it but its more likely bushings worn in the bearing carriers and/or the a arms. Check the lower shock bushings too. A little slack in each one adds up to a lot in total. The only way to get them to last is to install grease fittings.
