no power going to bulb? low beam works, no fuses for them, could it be switch, has anyone tested switch before?
thanks
Open up the pod and check where the wire comes up around the steering stem. Look for a broken wire in there and I bet you will find your problem. If it is like my wife's, the wire broke where it rubs the top of the stem every time you turn the bars. Not an easy fix.
thanks found it, someone must of pulled the wires to the light bulb to hard and they seperated the wires inside the covering. cut stripped back and crimped, taped, all set.
THANKS!!!
