11 850xp where the shifter Bell Crank lever attaches to the shift shaft the splines are stripped. Question is...to me it looks like if I replace the shift shaft that it has to be installed from the inside of the transmission, doesn't look replaceable from the outside. Am I correct? Or..keeping fingers crossed here...can it be replaced from the outside?
If it has to be replaced from the inside does anyone have any suggestions for a temporary/permanent way to fix it? I really don't want to have to tear into the transmission if I can put a fix on it.
Have you removed the bell crank to inspect yet? Most of the time the bellcrank is what strips out or cracks and not the shaft.
Thanks! I didn't have much time yesterday and just saw that the Bellcrank was rotating on the shaft, took it off this morning and yes it is stripped. Got one ordered, thanks again!
