Can anyone tell me if they have put twelve inch wheels on their magnum.I am trying to figure out what will work. Thanks in advance, Dave
I believe you can change the hubs to the older predator hubs on the rear axle then use 4x 156 bolt pattern wheels like the other Polaris machines, someone did it on these forums, do a search and find the thread.
huh????
I think the OP just wants to know if there are any issues with buying aftermarket 12" rims... like will the caliper rub the inside of the rim or anything. I've been wondering myself. Personally I have no F'ing clue why anyone would want 14" rims on a Scrambler. I can't find 25" tires and it pisses me off.
12 inch wheels
Yep i've done the swap. factory 12 inch polaris wheels on rear. Older predator hubs with the 156 pattern. You must run wheel spacers to get the width right.
