Hey guys, I have a quick question about the rear torsion bar and their links to the a arms. Are they supposed to be almost perfectly straight or slightly on an angle? My left one is tipped a bit. Right side is straight up and down
Let me know what yours look like. Maybe I have a bushing worn or maybe it needs to be loosened off and repositioned and retightened
Let me know what you all think
Cheers
I'm on my third set of torsion bar end link bushings. They took a lot of abuse until I went with hd springs. The bushings don't want to stay aligned, they rotated a little. As far as the arms that attach the links to the torsion bar they will eventually loosen up and have a Slight tilt to them. For piece of mind give the arm's bolt a check to make sure it hasn't loosened up on u.
Take them right off you only need them for high speed riding and it makes a substantial difference not having them in the mud.
Discussion Starter · #5 · (Edited)
Hey thx. So if I get what you are saying is the link bushing on mine is shot. So they need to be replaced. Does anyone make a better bushing than polaris? I was assuming I would get more than 800 miles before bushings went. Oh well
I tried to attach the parts diagram of the t-bar. Looks like I need item 9
As for the other part, the arm from link to t bar couldn't you just replace the bushing in there and fix that tilt?
What springs should I get to stop this from happening? Coil I just dial up spring pressure a bit?
Yes u need 8-#9's
The bushing between the tube and torsion bar usually is ok. The tilt comes from the metal to metal contact of the torsion bar and arm. It's just normal ware.
I went with epi hd rear springs because I had the rears turned up all the way and still had to much squat under hard throttle and upper speed whoops/water dams. That torsion bar is acting to much like a spring that's why the bushings are getting warn out so quick.
