What if any is recommended, I see Dalton says not for use with stock tires. Are any safe with stock and how easy is it to do the the home garage guy. I have had the belt off and am good with tools.
Clutch kits are beneficial in any application, even with stock tires. You can tune them any way you want depending on your riding style. Adam at Quadshop Customs can set you up with a clutch based on your riding style.
Exactly what lost cause said. Changing clutching to perform at it's best with your machine and your use in mind is always a good gain. I can set you up with a QSC kit custom done to your needs vey quickly.
