1 - 2 of 2 Posts
Was trailer riding Saturday on my 14 570 that has only 250 miles and 50 hours on it. Ran perfectly fine until I shut it off for a few minutes and then tried starting again and no fire. Cranks over fine but nothing, like getting no fuel or spark. Towed it home and sprayed a little starting fluid in the air cleaner when cranking as well as pumping throttle and it fired up for a few seconds so its getting spark. Is my fuel pump bad? a way to test without just replacing? I assume its located in the tank? i did check all fuses and also sounds like pump is running when you turn the key on. Thanks for any advice!
Discussion Starter #2
Forgot to mention that it does start with starting fluid and runs like normal until you shut it off and let it sit for 10 min and then just cranks with no start.
1 - 2 of 2 Posts
