I slapped this rack together out of aluminum and painted it up
Attached it to the inner framework with carriage bolts
Siliconed around the heads of the carriage bolts after socking up the nyloc's
Cut a slot in a tuff tote for the bar of my small saw to stick through, lots of extra room for fuel/bar oil, tools, etc. Used some scraps of pipe insulation to pack it in tight
Also holds two Walmart 2 gallon gas jugs. I have used these for a couple weeks now and they don't leak. I was shocked
Sweet rack man!!! Even better tracks!!!
I would take it easy on weight since the front lid is not terribly strong and you might break the hinges.
