Looking for a set of 14" OEM Sportsman Wheels. I have another set of spare tires I would like to mount on them. All aftermarket wheels that I find have the wrong offset and I do not want to go any wider.
What machine do you have? The 550 and 850s use a Rzr offset wheel so they are tucked in under the fender pretty well. Which is different from the 450 and 570 machines. I had the same issue with my 850. I don't like the alloy wheels that came on it so I opted for a set of OEM steel wheels instead. Same as you I didn't want to go any wider. I got my set from powersportsnation.com. You can check on line or call them.
Ok, same issue that I had then. Any wheel with a Razor offset which I think is like all positive offset. Maybe 1-6 for a front. I couldn't find any that I liked any better than the OEM.
Aftermarket wheels you would want 6+1 offset.
