Looking to get a little insight from anyone who is running 27” tires on there stock sportsman 450 without a clutch kit if anybody is I would appreciate the feedback, thanks!
Well I'm not but I can tell you a thing or two cause I know a thing or two. Typically you'll need aftermarket rims. IMO you don't NEED a clutch kit for tires smaller then 28". BUT you'll need to be in (L) when things get knarly. Also remember you're not working with a twin big bore so bigger tires that are heavier will noticably have an effect on the butt dyno. So on a smaller cc machine with a big wheel kit a clutch kit is advised. QSC from RVSPerformance is were it's at for a CK!!
