1990 trailboss 2X4
Alexander, I have a service manual that covers your atv, but from the info you gave I am unable to even start to find your problem. Do you know at what point you loose the spark? Is the spark non-existent, or just weak? Are you knowledgable enough to do the work for your self, if you can, I can give you some pointers as to how to check the ignition system. Hischild
i can almost garuntee its butchered wiring because very rarely will the cdi or magneto will fail unless your stator is bad which could happen
