1 - 12 of 12 Posts
Hello - Does anyone have any help in removal of the starter - cant find the bolts - any help would be greatly appreciated
thank you
Administrator
Hey Kaine and welcome to the site. Have you been able to get a hold of a service manual for the quad? The site has only been up for a few weeks and still under construction. We expect to have the site completely finished within a few more weeks.
You should have 2 bolts under the recoil assy, and then 2 more behind the belt covers, kind of a P.i.t.a
One of the bolts is part of the recoil housing, too. I got the whole thing off without removing the belt covers, but it required a lot of patience. All 10mm bolt heads. You would also need a clutch puller to get the belt covers off, so be confident you can get the last bolt back in on the back of the starter before you pull.
You are right! there are two bolts inside the recoil stater cover BUT there is a mounting bracket on the top side of the starter that is impossible to get to. You either pull the clutch cover and the transmission or you find a good sawzall and cut the bracket off or take it to the dealer and let him fix it for you! Sorry, I've had the same problem
1 - 12 of 12 Posts
