I bought a 1992 or 93 350 trail boss. It has a couple issues. The first is it's hard to shift into reverse. The second is the light for the 4x4 come on but I'm not sure if the 4x4 drive is working? Any help would be appreciated :nzd:
A few different problems could be wrong with shifting one is the idle to high does it get better if you put on the brakes to stop the clutch from spinning
allot of time it is the linkage is dry needs to be lubed have you tried just to shift it into reverse down by the transmission, and sometimes the rod between the shifter and transmission is bent a little
or you need to change the oil in the gear case or transmission a couple of times to get the crap out
Welcome to the board!:med:
