1 - 2 of 2 Posts
Recently 4wd quit working and cannot figure out why, flip the switch nothing but in 2wd sometimes 4wd will kick in when the machine is stuck not sure what is causing this? Normally left front is always spinning when locked in but just has stopped, but when stuck right front will sometimes lock in to help the machine get unstuck. All chains are tight with a little slack and all in proper places? Would really appreciate some help with this, thanks for all comments and other questions
Pull the front hubs apart, they are magnetic hubs and if there is crud builtup it could be causing them not to engage also checl your tranny fluid for any metal shavings as maybe your front drive gear has stripped itself out.
1 - 2 of 2 Posts
