1 - 2 of 2 Posts
Having issues with our 1993 250 4x4 with fuel. I have replaced the valve under the fuel tank, it was very loose. Now it appears to not be pulling fuel. I think the previous owner routed the fuel line improperly. It was above the black metal bracket that holds the fuel tank in. This seems to me to be up hill, against gravity? Should it not be routed below this bracket? I cannot find a diagram that shows the routing. Can anyone provide some guidance on this for me?
Thanks!!
I just took the tank off my 97 and it has the fuel line going between the tank and the plate. Your description describes what I saw as I was taking it apart. I suspect the fuel will have no issues flowing as it is still lower than the fuel in the tank.
1 - 2 of 2 Posts
