1 - 2 of 2 Posts
Hello - Got a 1993 Sportsman 350, 2 stroke, 4x4. I can't get it to idle at all. Always have to crack the throttle open a bit to get it started, then it will not settle into idle. Tried adjusting the idle stop screw, no effect at all. Tried adjusting the idle air screw, no effect at all. I thought the pilot fuel circuit was plugged, but it seems to be open. I can blow air through it. What am I missing here? Also, on the top of the carb there is a small hose barb fitting with nothing attached to it. Sort of looks like a vacuum fitting or maybe the fuel tank is supposed to vent to that? Thanks in advance - Steve
1 - 2 of 2 Posts
