I have a 94 400L 4x4. It's not getting fire (most of the time). I've put a new CDI box, coil, plug wire and wire connector on it.
Every now and then, it will get fire. I take the plug and hold it to the block while I crank it. I can see spark in the gap. I put the plug back in, start it, move it about 10 feet and it loses fire again.
Can a bad stator be intermittant like that? Any ideas on anything else to check?
Any help would be much appreciated.
You will need to get the specs from a service manual. Check the ohm resistance of the different wire combos. Sorry can not remember the spec right off hand.
