How do you get it out? Starter is bad but can't figure out how to get it out. Top right bolt easy, bottom right one almost impossible. Any help from anyone who knows. Thanks
I just did this on 1994 400L. It has offset Bendix...not sure if your's is the same. I am guessing it is the same becuz of the difficulty of getting to the bolts. I would truly suggest getting a Clymer manual. It is not hard to do just a very long procedure and an extreme pain in the butt!!! Clutch cover off, recoil cover off (need a punch becuz dowel pin(s) holding it on, remove clutch (special tool needed & I used impact wrench to break free from shaft taper), etc. Really get the manual. I'll add to this when I get home and next to manual.
