Hey Guys Got a bit of sn issue
Just picked up a 94 sportsman and it seems to have electrical issues
The key switch sometimes wont kill it
The kill switch works fine
When the key switch wont kill it also the rev overide is messed up, if you put it in rev without the overide pressed the engine dies
any ideas where to start with this finicky issue
side note looking for ideas the speedo and odometer are not working at all
Oh and awsome forum found lots of info so far
That would be an issue with the rev limiter its self. Pull the black wire coming from it and that should solve the problem.
As far as the speedo, check the cable.
Welcome to the board. :med:
