1 - 20 of 23 Posts
Hy guys,
I have a 1995 250 Trail Boss that I have recently rebuilt the motor. The bike was given to me as a basket case so I don't know how it ran before.
Problem is that the bike will start and idle and when throtled it will take very little of the gas only reving up to a couple hundred rpm. over idle. after that the more you press the throtle open the motor just bogs as if it is getting all air and no gas. I've been though the carb four times and doubt at this point that the problem is in there. Also I've tried to rotate the magnetic pick up to se if it could be a timing isue to no avial.
Any help here would be great.
Thanks, Ron.
Damn this DALE guy is a smarty pants! :rock: :You_Rock_Emoticon:
Discussion Starter · #6 ·
No. I'll go out there and try that now. The guy at the Polaris shop told me to be sure the air box and snorkle are installed. Did that and it made no differents. By-passed the gas tank by putting a can of fuel at floor board height, also made no difference.
You will need a mighty vac or a hand pump with a gauge that goes to about 7 lbs. Flip the carb upside down and hook a fuel line to the gas inlet tube and the pump [make sure all gas is drained from carb before flipping upside down]. Pump up between 5 and 7 pounds you want it to hold at that pressure for at least 5 to 10 minutes. If it leaks down then you need to replace the needle valve or as some people call it the needle and seat. Good Luck!
Greg
follow your throttle cable down to the handle bars, you will find a wire conection, pull it apart and try you bike. it is the throttle override.
If you bike idles but won't rev up like there is a limiter, this is probably your problem
i have the same problem. i can't believe this, i've seen this on every site and no one has been able to fix it. i've tried everything but didn't know there is a throttle override. only for reverse. i have a 2001 Trailboss, please help. Where's this connection exactly?
I did that. 3 times. i've cleaned everything even the gas tank. does a 2001 or 2000 have the throttle override wire? that i could check
i dont think they did. i dont think the older machines had that, but im not totally sure. i could be wrong there. you do have a rev limitier that possibly could be bad. thats mounted up on the frame up front.
also have you checked you fuel pump lately. you might need a new diaphhragm and gasket set.
Part Number Description Quantity MSRP*Ext MSRP In Stock
4010137 LIMITER RPM 350 HZ LR44-3
Part was advanced to minimum order quantity 1 $71.54 $71.54 Yes
What would the rev limiter look like? i have had the fuel pump off and it appears fine, and i also think the diaphragm is fine but how would i know, just check for holes? its easy to get too since it's up front.
here is the fiche #34 is the rev limiter
# Add Part# Description Quantity
1 2460706 HARNESS-MAIN,CONNECTOR,T.BOSS Substituted by 2460817 1 Usage
2 2201795 KIT-CIRCUT BREAKER,FAN 1 Usage
3 5211391-067 ISOLATOR,TAILLIGHT 1 Usage
4 7621470 RIVET(50) 2 Usage
5 7670054 NUT, PUSH-ON (10) 2 Usage
6 7555916 WASHER,NYLON(10) 2 Usage
7 2432034 TAIL LIGHT ASM. 1 Usage
8 4032046 LENS,TAILLIGHT 1 Usage
9 4032029 SCREW, TAILLIGHT 2 Usage
10 4030043 BULB,TAILLIGHT 1 Usage
11 4032045 GASKET,TAILLIGHT 1 Usage
12 4032064 BACKING,TAILLIGHT 1 Usage
13 7080138 STRAP PANDUIT(10) 12 Usage
14 7670109 CLIP-ROUTING 3 Usage
15 7541925 NUT(10) 4 Usage
16 7512027 SCREW(10) 2 Usage
17 5431769 COVER,BATTERY 1 Usage
18 2200361 BOLT,BATT,KIT(SHORT) 1 Usage
19 4010095 CABLE,BATT/ENG.,BLK. 1 Usage
20 7010032 HOOK-BATT.H/D(10) 2 Usage
21 5410424 STRAP,BATTERY HOLDDOWN 1 Usage
22 5432077 TUBE,BATTERY VENT AR Usage
22 7080303 CLAMP, POLY 1 Usage
23 5810290 PAD, BATTERY 3 Usage
24 4140006 BATTERY 1 Usage
25 4010094 CABLE,BATT/SOLENOID,RED 1 Usage
26 ------- Magnetic Switch (See Magneto Pg. D4, Ref. 13) 1 Usage
27 4010093 CABLE,SOL/STARTER 1 Usage
28 7512007 SCREW(10) 2 Usage
29 4010249 SWITCH-THERMISTER,LR-60 1 Usage
30 8360012-04 EDGE TRIM-BLACK,04 CM 1 Usage
31 4060191 RECTIFIER/REGULATOR,LR-35 1 Usage
32 7512018 SCREW(10) 5 Usage
33 5132214 SINK,HEAT 1 Usage
34 4010137 LIMITER,RPM,350 HZ,LR44-3 1 Usage
35 7512017 SCREW(10) 2 Usage
36 7571602 WASHER(10) 4 Usage
37 4020149 CLIP,ROSEBUD 3 Usage
check to make sure nothing is plugged, diaphragm looks good and intact, and no leaking, gasket look good and intact
- 3085275 PUMP, FUEL * (Incl. 1-4) 1 Usage
1 3084999 SCREW&WASHER ASM. 1 Usage
2 3085000 SCREW&WASHER ASM. Substituted by 3085356 2 Usage
3 3084591 SCREW&WASHER,(10) 4 Usage
4 3084998 SET,DIAPHRAGM&GASKET 1 Usage
i feel like an idiot. I can't tell where #34 actually is by the diagrahm. I know the other two diagrahms but that one i don't recognize.... I'll look when i get home from work. thanks for the suggestion and the diagrahms.
250 Trailboss
If I remember correctly, it is located near the base of the handle bars, near the head light. if you follow the throttle cable down, you will find the electrical connection , hopefully you will solve your reving issue.
As far as the issue with the bike not running except using the choke- that sounds like a fuel problem- have you checked the fuel filter?
good luck
ok, last night. started up with choke engage (same problem) verified it by doing it 10 times. then pulled the main plastic piece over the gas tank off. tried starting it again. started up and i used it for 45 minutes no issues. I need to plow the driveway so I never checked the fuel filter but it's almost like the air intake is covered to much or something. doesn't make sense still. I'll keep working on this, by running it everyday for 45 minutes to verify problem didn't come back. I rode it around with no ferring on it and it was fine. it can't be the ferring blocking the air intake but it worked so i'm happy,...................today.....................
1 - 20 of 23 Posts
