Hey guys new user here! I just picked up a used 1995 magnum. It does not currently run but I am hoping to change that. There was no rear shock on it so the rear is completely dropped. I just ordered a 1989 trail boss shock/spring off ebay that I hope will fit. I will change the oil and spark plug. Are there any good guides/videos on carb cleaning? Also, do you know where I could find the side plastic or would the side plastic from any other model fit? I look forward to reading and learning from you all. Thanks!!
I have the same machine which I don't know why I've put so much money into it but I enjoy fixing it. I've gone through the carburetor completely, bypassed the stator and installed a RM Stator, replaced the CDI box, replaced the Pulse Pick up coil, replaced many seals and replaced front wheel bearings, new sprockets and currently I'm trying to replace my Fan sensor in the radiator which they are not longer available. I have no idea about the side plastic, Ebay is probably your best bet. You need these basic things for the thing to run, Spark, Compression and fuel. I knew nothing about the Polaris ATV when I bought this, had I known a little more I would probably
have passed on this machine.
@4-wheeler thanks for the reply! I sure hope I can get it to run. I got it for pretty cheap. I don't mind putting some money into it if it's a solid machine. I have never owned anything polaris. This one seemed to be well kept based on looks. I am going to try to get the rear shock on, oil changed, carb cleaned and see what happens from there. Are there any other good groups/forums that know about this machine?>?
