I am new to this site and am looking for help troubleshooting an issue I am having with my AWD system on my 1995 sportsman 400. I have been testing the electrical system per the service manual and am trying to determine if my gear selector switch is faulty. I have power going from the main circuit board to the switch but am not able to get power coming back. I tried jumping from the red/white wire connection on the main panel to where the grey/white wire coming back from the gear selector switch connects to the main panel to see if the AWD switch on the handle bars would light up with no success. Any suggestions on what else I could try to diagnose if this switch is the issue? Thanks for your help.
Go from a connector that gets hot with the key on to the grey-white wires on both hubs, this will by-pass shifter switch, awd switch will still turn it on and off
Thank you RussC. This was helpful. Found out it was a shift linkage adjustment issue with a burnt out light on the AWD switch.
