1 - 12 of 12 Posts
WoW I finally found the perfect site for all my Polaris needs.
I have a 1995 Trail Boss ,My question is simple do you have to remove the fly wheel in order to remove the starter? I have removed the recoil cover and found two 10mm bolts but the starter seem still installed? Is there any more bolts that I am missing? Any help would be great!
Born to hunt!
Forced to work::zahn:
no, there are only two mounting bolts, and no you dont need to remove the fly wheel. just got to play with it a little bit.
I'll keep trying It still removes from the back of the fly wheel?
hey i just looked at the microfiche and saw something im not quite sure. on a lot of polaris models it is only 2 mounting bolts, but it almost looks like yours has 4....two #16's and two #9's
Thank you ,
You are right It did have 4 just got them removed and on with the rebuild.
did you need to remove the clutch housing to get to the other two bolts ?? need to do it on my 94 300 2x4 looking in a clymer manual it says i need to remove the reat fenders and rear rack just to remove the clutch cover boy they sure don't make it easy to work on these things.
Thats an UNDERSTATEMENT No ROOM at all. I have almost everything removed and out of my way . And it was still a pain in the butt !!!!!
I ran it until starter rope broke. I looking for a used on on e-bay but not having any luck. The more items you remove the easier it it to fix.
om mine i cant even see the starter. gee's pain in the rear just to put in a spark plug.
if you go to utube there are clips on how to put on a new rope. looks pretty easy to do after you get the it off the motor
1 - 12 of 12 Posts
