1995 Polaris Xplorer 400
Hi, I'm new to the site and have a few questions. I've been riding since 1994 and bought my Xplorer new in 1995 and had it ever since. I only have a 1800 miles on it so its not that much wear and tear. OK, so there are the questions. Thanks in advance for your help!:anbet:
I have a 95 Xplorer that when running has a knocking sound at idle. I've checked the oil injection and cleaned the carb everything looked good. It go's away when driving it. I could send some audio if it would help in trouble shooting the problem. I had not rode it in 2 years so I change out the fuel and cleaned the carb. Checked the injection oil, counterbalance and transmission oil. It was stored inside and I had pulled the manual start every so often to keep the cylinder walls clean.
Is there any lubrication that is needed on either the driven or drive pulleys? When I checked it there was a lite coating of belt dust but the belt didn't look worn or cracked. Should I remove this residue?
I also have a rear shock that needs to be replaced. Is there a cheaper shock then the one listed on the discount polaris site?
This is not related but I am new as well and I want to know how in the world you post a new thread on here. I can respond fine but I dont know how to start a new thread/post
Mine did it and it was the Clutch belt slapping the top of the Clutch Cover! It went away when i put a new Belt on it!
