1 - 20 of 35 Posts
I just purchased a house and with it came a 1996 magnum 425...that hadn't ran in 2-3 years. I went through and cleaned the carb first thing, filled it with fresh fuel and it fired right up (with the pull start, battery is no longer good). Well beings this weekend was opening weekend of deer season, i got to try it out. Saturday it ran great, it saw mud, water and never missed a beat. Loaded it up and left it in my pickup over night and half of the next day. It rained on it all night and most of the next day (this, I believe is key) I started it the next day and it starts and idles fine, but will not rev. It revs just high enough to engage the transmission and move slowly.....seems electrical? when you try to rev it, it cuts out and miss fires. Anyone have any idea??
It was all the sudden though. One day it was fine, the next it was like this.
Update: I pulled the "black wire" off of the control box under the handle bars and everything ran fine. I went to shut it off and it wouldn't shut off. I plugged the wire back in and shut it off and now even with the wire plugged in, it runs fine.....so I guess I will run it until it acts up again?
I had a problem like this, and I removed the airbox and now it runs like a top. also had some plug to wire connection/rust issues. But now golden, not sure what to do about the airbox though. Mine actually sputtered at WOT and ran rich with the airbox on but off fine(no restrictions I even removed the filter). probably two different problems we are having.
Try pushing the override button,Look in ETC, electronic throttle control box on handle bars, see if its full of water, also make sure slack in throttle cable is set right, 1/8 inch, slack at thumb throttle, you adjust it where it screws in the etc box on those machines
Thanks boss, but I have tried these things though, I'm not that worried about it. I think I have a cracked plug I have an idling problem it will be just fine then it will sound like the plug is arcing then die, so I'll fix that first.
Pull apart all your electrical connections and put a little dielectric grease on them, as well as the spark plug boot. Sounds like you got a wet electrical problem and that should help a lot of it.
Didn't think about the dielectric grease I have a tube in my toolbox lol thanks man
Discussion Starter · #12 ·
Well update. It is doing it to me again. Wont rev. This time it was completely dry (Has bee parked up under the carport. A new development though, when it was acting up, I went back to the carport and went to shut it off. I turned the key to the off position and it kept idling. I left it there for awhile (Maybe 20 seconds) And it shut off. I turned the key back to on and started it. This time it revved just fine again, and when I turned the key to off, shut off like it is supposed to. Seems electrical still???
I would say to check speed limter wires one could be grounding out. Next move to the cdi unit or the key switch. Check the wiring on both.
1 - 20 of 35 Posts
