My ATV has the master cylinder that the hose screws directly into it . All the replacements i have found has the banjo bolt connection.
My question is the hose fitting and the banjo bolt the same size.
My handle bar assembly looks like this.
Thanks for any help.
Here's a new one like you need for $38 or you can get a rebuild kit for the one you have for about $25.
Thank you polman500 for your reply.
I bought a kit and broke the smaller cup seal installing it. To add injury to insult I stuck the pick in my hand when it broke.
I think I’ll just replace it with a new one.
BTW, a inverted flare to banjo adapter is available although perhaps difficult to find at brick and mortar stores. The OEM master cylinder used a inch dimension inverted flare connection and the banjo fitting is metric, but they can be adapted.
