Guys,
I have an 1996 polaris 400 explorer. Whats the differance between the sportsman and the xplorer?
Also dose any one have clutching ideas to increase power to the ground or should I go get a kit.
I hate this quad as it sounds like its running rich all the time. I havent jetted it down. It also smokes bad. Like a 2 stroke but worse. Any ideas. Havent looked at the oil pump to verify whats it set to. Thanks for any info.
Gee - that was a long time ago, but they used the same two stroke engine and front drive system, so other than the model name, I'm not sure what other differences there migh have been.
to the forum
Your question has now been logged into the queue and the next available forum member will answer you shortly. You will be given more advice than you could hope for.
The real shortage in this country is common sense.
