1 - 8 of 8 Posts
Can anyone tell me what tool is used to adjust the rear shock on the Polaris Xplorer 1996 300CC 4x4 ? It has different level of tension options, but no way to adjust without the proper toool? :augenreib:
They use a spanner wrench which came in the tool kits. If you do not have one ask a mechanic if he has a spare one that will fit your machine. They have a lot of different size ones. I must have at least a dozen of them.
And welcome to the board!
Discussion Starter · #4 ·
Hey Dirty Dawg Dale
Would you want to part with the one that will fit my 1996 Polaris Xplorer 4 x 4 ?
Name your price......
I would gladly give you one if I was sure which one you needed. Keep in mind they had a lot of different shock applications over the years. If I had a picture or dimensions I would see if I have one laying around.
Discussion Starter · #6 ·
Wrench
I will measure the diameter and the distance between the teeth on the adjuster. Perhaps this will help you out. I will buy it from you.
Parker
Dale thats very nice of you! You dirty dog you!:bad::five:
1 - 8 of 8 Posts
