1 - 2 of 2 Posts
1996 Polaris 400 2 Stroke
Runs good until it gets hot then it boggs down when I give it full throttle. The machine will still pull and will take gas if I give it to it slow but some times you have to have the power right away an it boggs down. will not pull a hill when it is bogging down. Does not do this all the time but mostly if hot. I have had it start out this way after riding hard a couple of days in a row.
I have cleaned the carb, changed plugs on the trail which helps some times.
Tried leaning out the carb and making it too rich. I have had it fix itself by changing the plug and then running the crap out of it. May work may not???
Any ideas?
bogging down
check your piston it could need to be change u can check it by take the carb off and the reeds when u do that u can see the piston
1 - 2 of 2 Posts
