Hello all,
I have an awesome 96 Sportsman 400. Hunts like a animal and has for 17 years. This year, the carb. drips gas out of the bottom with the engine off unless you turn the gas valve off. ( It will empty the tank on the garage floor if you forget to turn the valve off.) I was told by a Polaris mechanic that
"the needle valve is worn out and not seated."
Is this an easy fix by me and does this sound like the truth.????
Any help is appreciated.
