1 - 2 of 2 Posts
I have a 500 that will not shift into reverse when I got it it was stuck in high forward I figured out that the shifter was froze. I bought a new shifter now it shifts high an low no problem. I disconnected the linkage to the trans and the lever on the trans will not move to reverse. It is in a heated garage. I dont have a owners manual so I'm not sure if you need to push the brake or something to get into reverse I have tried that and still wont shift. When I tried to move the lever on the trans it seems to be jammed. Any ideas would be appreciated and if I need to pull the trans. and separate the case any helpful hints would also be appreciated. I do work on things like this all the time but this has me stumped. Thanks Mitch
Welcome to the board!:biggthumpup:
1 - 2 of 2 Posts
