Hello everbody, i am new to this forum.
I have a 1996 Sportsman 500 and i am not getting spark to the plug.
What i think led up to the problem:
The only thing i know is, i had a dead short in the battery out in the woods.
I hooked a jump pak to it, and it still would'nt turn over.
Thinking it WAS a dead short, i disconnected the battery. After i hooked the jump pak back up, it started right up, and drove it home.
A few days later, i went to start it and there was nothing. No spark.
I called a guy at a shop and he said you can not run that atv without a battery hooked up or it will fry something.
I cant remember what he said it was.
This model year does not have the Surefire module.
Any ideas anybody?
Regulator, fuse, relay, stator?
Thank you very much
Ron
There's a breaker right next to the battery in a plastic cover. If it gets to hot, it'll click off and when it cools turn back on. Sounds like that's what happened to you.
Thanks RENOBADBOY!
Is this a reset, or replace part type repair?
Thank You for your reply.
Allmudd2l
Actually, this happened back in 2001, and has been in storage ever since.
So i think i can rule out breaker cool down. Is there a manual reset on it?
Anybody know where i can get a wiring diagram?
The starter does turn over, but the lights don't work, except for the blue high beam indicator which does.
I think it may be something under the front access cover maybe?
My closest dealer went out of business, and the next closest is quite a way from here.
I called them and they said they had no idea, but bring it in. I really don't have that kind of money for a witch hunt. :hmmm:
Just let there be spark. :)
ANY more sugestions would be highly appreciated. :veryhappy:
Thank you all
Allmudd2
Check out this link, it is very informative.
1996 Polaris sportsman 500. Electrical problem. If the hub - JustAnswer
I posted this link in a similar thread so anyone following that thread would see it too.
I am not trying to keep this thread on top, just returning to the community information i thought to be helpful to others and my situation. :veryhappy:
From this information, i have gained weak intermitent spark now. What would likely cause this? CDI, ETC, Coil?
Thank You,
Allmudd2
