hello, I have been lurking around here for some time and have found a lot of answers here, much appreciated. But I have been unable to find a Polaris or aftermarket bearing part # for the gearcase output shaft/bulkhead that goes to the rear brake assembly. This is the same shaft that the front sprocket is attached to and extends to out to the rear brake rotor c-clip and bearing is inside the bulkhead. I understand that it is no longer available unless I purchase the whole bulkhead assembly. I was hoping someone may have ran across this situation and have just the bearing part number(aftermarket preferred). I am sure this part is the same on a lot of 90's model Polaris atv's.
Post in wanted section
You may have better luck in Wanted Section going for a used part. Luck!
Banned
1040414-067
1996 ATV XPRESS 300 GEARCASE/BRAKE and CHAIN COVER MOUNTING XPRESS 300 W969530 and XPRESS 400 W
1996 ATV XPRESS 400 GEARCASE/BRAKE and CHAIN COVER MOUNTING XPRESS 300 W969530 and XPRESS 400 W
1996 ATV TRAIL BLAZER ES GEARCASE/BRAKE MOUNTING - W968540
1996 ATV SPORT 400L GEARCASE/BRAKE MOUNTING - W968540
1996 ATV MAGNUM 2X4 GEARCASE/BRAKE MOUNTING Magnum 2X4 W967544
1996 ATV TRAIL BOSS GEARCASE/BRAKE MOUNTING Trail Boss W968527
1995 ATV 300 2X4 GEARCASE/BRAKE MOUNTING 2X4 300 W957530
1995 ATV 400L 2X4 GEARCASE/BRAKE MOUNTING 2x4 400L W957540
1995 ATV TRAIL BOSS 250 GEARCASE/BRAKE MOUNTING Trail Boss W958527
1995 ATV MAGNUM 2X4 GEARCASE/BRAKE MOUNTING Magnum 2x4 W957544
1995 ATV SPORT 400L GEARCASE/BRAKE MOUNTING Sport 400L W958540
1995 ATV TRAIL BLAZER GEARCASE/BRAKE MOUNTING Trail Blazer W957221
1994 ATV 300 2X4 GEARCASE/BRAKE MOUNTING 2x4 300 W947530
1994 ATV 400L 2X4 GEARCASE/BRAKE MOUNTING 2x4 400L W947540
1994 ATV SPORT 400L GEARCASE/BRAKE MOUNTING Sport 400L W948540
1994 ATV TRAIL BLAZER GEARCASE/BRAKE MOUNTING Trail Blazer W947221
1994 ATV TRAIL BOSS GEARCASE/BRAKE MOUNTING Trail Boss W948527
Polaris - 1040414-067 - SUBSTITUTED BY 9999999
Welcome to the board.
