I need some ideas from you all.... I have a 1998 425 Magnum 4x4 that is making a clicking noise from the front end when riding. I have checked everything that I have knowledge of.....
I replaced the wheel bearings on one wheel thinking that was the noise, it helped but there is still a clicking sound. I even jacked the wheels off the ground and ran it in the shop, trying to get a better idea of what was going on. The weird thing is that it wouldn't make the noise with the tires off the ground. I am baffled...u joints and cv joints seem solid (no slack when manually pulling on the shaft)......please help? Could it be a ball joint?
Welcome to the board!
possibly the rollers in the front clutch assembly in the front hub?
1 7512325 BOLT(10) 8 Usage
2 5211326 DISC, BRAKE Substituted by 5242935 2 Usage
3 3610019 SEAL, FR. HUB 2 Usage
4 5211148 PLATE, ARMATURE 2 Usage
5 1520214 CLUTCH ASM,FR.HUB,E/M,HVY. Substituted by 1520281 (Splined Drive Shaft) 2 Usage
6 3554506 BRG,TAPER.ROLL.CONE 4 Usage
7 3554507 BRG,TAPER,ROLL CUP 4 Usage
8 1520243 HUB ASM,SHRT(3-LOBE)W/BRG RACE (Incl. 3, 7,15) 2 Usage
9 3250028 CAGE, ROLL 2 Usage
10 3250010 ROLLS 12 Usage
11 3250032 SPRING,GARTER 2 Usage
12 3250031 SPACER Substituted by 1321814 (Splined Drive Shaft) 2 Usage
13 3250030 CAM (Splined Drive Shaft) 2 Usage
14 7052045 PLUG,PIPE 2 Usage
15 7515523 STUD(10) 8 Usage
16 1525017 VALVE, RIM 2 Usage
17 1520179-117 RIM,FRT,6X12(SILVER) Substituted by 1520269-117 2 Usage
18 5410568 TIRE,FR(25X8-12) (25x8x12) 2 Usage
19 7556004 WASHER 2 Usage
20 7542810 NUT, SLOTTED(10) 2 Usage
21 7661401 COTTER PIN(10) 2 Usage
22 5410470 O RING 2 Usage
23 5432611 CAP,HUB,3-LOBE,AWD 2 Usage
24 7512027 SCREW(10) 6 Usage
25 7542459 NUT, FLANGED(10)
front yokes in good shape(not too much slop on the shaft??)
front rotors pretty true?? will cause the brake pads to jump around and make that type of noise
chain and sprockets in good shape,no bent links or missing teeth
