Any assistance would be appreciated.
First off I only know a little about engine repair by observering my father as a mechanic many moons ago.
I have a 1999 Trail Boss 250 (2 Cycle) that won't start. I checked the compression without holding the trottle in and it was 70 PSI. I'm not sure if holding the trottle makes a difference but I did see instructions afterwards that stated to hold the trottle all the way when checking compression. When I place the spark plus again the engine and try and start it there is spark. However it doesed seem to be a very bif spark, maybe weak but I can say for sure.
When I prime it by putting a small drop of gas in the cyclinder head and then reinstall the plug it still don't start most of the time. It seems to be flooded and will start after a delay or after holding the trottle in. I failed to mention that I have the tank off and I cleaned it out thinking there was dirt in the tank. I have already burned all of the fuel out of the fuel filter and lines previous when it finally started once. If I put just an extremely small amout of gas in the cyclinder head then it will not start at all.
I'm thinking that maybe a weak spark maybe the the cause and if so what would cause the weak spark? I have tried three new plugs.
Also before the problem got really bad over a 2 week period the motor was flooding out when idling for 4-5 minutes
Anyone have any suggestions?
Check the compression again holding the throttle wide open. Use a spark tester that reads gap and let me know what kind of gap it's jumping. The more information the better, i'll do my best to help.
Welcome to the boards!:jean:
Thanks for the reply ImHuntingCrazy.
unforfunately I had borrowed the compression testor from a Neighbour who borrowed this from his work place. He is a Machanic but works mostly on heavy duty construction vehicles. He figured the problem was caused by low compression but I think there is something more because over a two week period it went from starting on the second pull no not starting at all. I also do not have the spark testor that you mentioned either. I ahve a Digital Multimeter is there away to measure the volatage from the coil to see if it is good?
just did a compression test on mine and tryed with out opening the throttle and with. closed it was 120PSI open about 121 122PSI so not much of a diffrence. so at 70 you need to rebuild it. mite of broke a ring and thats what droped it all of a suden
1995 trailboss with weak spark
I have 1995 Trail Boss 250. Died while riding. Found no spark at all replaced the coil and the magneto, now I have weak spark. It will light the bulb style spark tester but will not arc out the end of the aother spark tester. Anybody know whats wrong?
Thanks Chuck Nave
You need a top-end rebuild. Could simply be worn rings/bore or could also be broken piston skirt, etc.
