1 - 2 of 2 Posts
Hello all! I spent days trying to find an LED light to replace the low beams that mounts in the same location. I saw a couple others that mounted to the plastic below, but I didn't want to do that. I found a set of LED cube lights at harbor freight for about $20 a piece that looked like they might work so I gave them a try. They worked perfect! I figured I would share this so anyone else thinking about doing the same thing could save a little time searching. They mounted directly to the stock light position with no modifications on that end. I did have to cut the connector off the harness, but the lights came with a new connector that I spliced in with heat shrinks and came out looking almost factory. I will attach some pictures, here is a link to the lights I bought:
Tire Wheel Vehicle Motor vehicle Automotive tire
Tire Wheel Combat vehicle Vehicle Motor vehicle
Automotive lighting Wheel Automotive tire Tire Motor vehicle
Wheel Tire Vehicle Automotive tire Combat vehicle
Wheel Tire Vehicle Combat vehicle Automotive tire
Wheel Tire Combat vehicle Self-propelled artillery Automotive tire
Font Line Window Pattern Screenshot
to the forum
Ball Gas Font Vehicle registration plate Automotive lighting
Reactions: Kgilcris24
1 - 2 of 2 Posts
