*** SOLD*** THANK YOU***
I have a set of 26x9x14 & 26x11x14 Roctane tires that are mounted on 14" STI C7 wheels (4/156). Will also include lug nuts for sportsman or 550/850. Only 220 miles on them. $650.00
Also Selling a set of 26x9x14 & 26x11x14 Roctane tires that are mounted on 14" STI HD3 wheels (4/156) with lugs $650.00
Local pickup only. Located in McHenry IL. Call Thor at 815-321-3888
if they fit a 800 sportsman, and you could hold them till end of dec or early jan, id buy em. ill be heading back to Wisconsin. I could even put down half to hold.
They won't fit your 800 without wheel spacers.... as the Value vs. XP Series wheel offset is different.
oh ok. so basically any 14in wheel im gonna need spacers?!
No, an XP rim on a Value machine will require spacers. THe XP series has less back spacing (shallower rim face). Spacers will always be an issue in the Value (400, 500, 570 & 800) vs. XP (550 & 850) rim swap.
Discussion Starter · #7 ·
These will fit the Sportsman 450/500/700/800 yes. The offset is 4+3 giving them the room needed for the larger wheel width. Here is a picture of one kit mounted on a SP500.
Discussion Starter · #8 ·
Here is a list of what they will fit.
Sportsman full size 1998-2014
Sportsman 550/850 2009-2014
RZR 2009-2014
RZRS
RZR4
Ranger
